Results 1 to 5 of 5
Thread: 4.8 to 5.3 help
    Apr 2011
    4.8 to 5.3 help
    I have a 1999 silverado with the 4.8. Im swapping in a 2002 6.0, Im guessing i can bolt my original 4.8 intake on the 6.0, correct? also, can i use my original 4.8 injectors or do i need the 6.0 injectors? If i do need the 6.0 injectors, will my harness plug into them? also, is the flexplate on the 4.8 the same as the 6.0 or will i need to be sure to get the 6.0 flexplate also?
    Apr 2011
    sorry about the topic mistake, supposed to be 4.8 to 6.0..
    it will all swap over and work
    Simple: 408 on steroids!
    single digits coming soon!
    Mar 2013
    Long Beach California
    im not challenging what skeet said as hes been around longer but if i was you just to be sure, double check the stock serial numbers on the injectors for each. i never checked myself but i would be suprised if they were the same. but like i said, im not sure. they might be. if they are different numbers, find out the specs on each to make sure they are at least relatively the same. if so, then id say your good to go as long as you stay stock. just my .02
    CALI LEGAL ENGINE SWAP!
    Aug 2014
    California
    Quote Originally Posted by mopower440 View Post
    Here's the thing, 4.8s came with a 4L60-E all across the board. A ton 6.0 motors came with a 4L80-E, HD flex plate I believe (128 teeth).and those came with oil coolers. A ton of 6.0s were used with 1500 Denali's in 2002 with a 4L60-E as well 4L80-E as options. 6.0 VIN U out of Silverado 1500HD and up came with 4L80-E. Find out what your 6.0 came out of. I checked fuel rail, and injectors for kicks. They are all identical 4.8, 5.3, and 6.0.
