Page 1 of 9 1 2 3 ... LastLast
Results 1 to 10 of 87
Thread: figuring estimated HP
    Pittsburgh, PA
    here is a formula for figuring flywheel hp as an estimate based off duty cycle and size of injectors
    injector size x duty cycle / BSFC x # of cylinders
    example...
    72.98 x 1.15%=83.927
    83.927 / .65 = 129.118
    129.118 x 8 = 1032.94 fwhp
    fwhp x loss % - Fwhp = rwhp
    1033 x .20 %= 206.6
    1033- 206.6 = 826.4rwhp
    again this is all a generalize calculation of power and should only be taken for bench racing
    _________________________ numbers used are my injector size and my duty cycle____________________________
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    its alot easier to go from
    trap speed and weight of veichle
    .00426 x 145 mph = 0.6177
    ( 0.6177 )3 = 0.235685
    ( 0.235685 ) x 4200 = 989.877 rwhp
    its very close to actual HP #'s
    Pittsburgh, PA
    Quote Originally Posted by flaco View Post
    agreed but if you dont have track times or weight going off this works
    but if that is your actual number then a 200 shot isnt all thta you were spraying. saying you made almost 800rwhp NA...that wold be the worlds record
    412 Motorsports
    what if u did not have tunning sofware???
    it just may be, jealous????? haha
    Pittsburgh, PA
    im not jealous bud, never have been. but on different note for RPM to go same mph as you did they hit their 427 with 450 shot....motors are similar as well and vehicles are similar as well in weight....so let that as it is
    412 Motorsports
    they must be using a 3 speed with no lock up bro. and a 1.30's 60' means less mph as well with faster time..
    so as i see it you dont know much about what actually takes to achieve that, just watching the vids wont tell you much bro. so go sit back in your computer and keep on dreaming!!!!
    Pittsburgh, PA
    alright bud, youre the god. hows that sound? ill sit back and let you post up results of your truck. But if your truck did make almost 800rwhp thru a 80e you would have mother of all NA LS motors. Or the fact your spraying more then your are allowing ppl to know. either way i dont know what im talking about and ill sit on the couch.
    o and what am i dreaming of? sure isnt being the fastest or etc. no need to get defensive
    on another note. you said blacksheep sprays 300 to go 9.9s right? his 408 made low 500s NA and his truck is pretty light..... and your truck had dyno'd what low 500s as well NA before the recent cam swap....a 200 shot on top of that in a heavier truck isnt going to get same results.
    412 Motorsports
    you make me laugh, since you know everything LOL, the world needs people like you.
    keep on hating bro.. rock on.. do u really want me to detail everything i have done and how i did it to you, uhhhhh, no.. go find out for yourself keep on trying
    Pittsburgh, PA
    why so defensive? is it your nature?
    412 Motorsports
    ff_jeff Guest
