Results 1 to 7 of 7
Thread: who makes this hood?
    Jan 2007
    Hurst
    It looks like the goodmark hood. I wanted to see if anyone can verify that for me? Before i order the wrong hood... Thanks
    Nov 2006
    Plano, TX
    Goomark makes one like that in steel and FG; VIS racing makes one like that in FG and CF.
    Mr. P.
    Aug 2005
    St. Anthony, Indiana
    Stylin concepts has a price of $450 for the goodmark
    http://www.stylinconcepts.com/part.aspx/pa...7/categoryid/25
    Oct 2005
    drinking your alcohol
    i like the look of the "widemouth" opening in the scoop, it works well with the front grille IMO
    DamnYankee: my nana failed
    Jan 2007
    Hurst
    yeah bad thing is its not fully fuctional... might have to do some custom rigging once i see the inside of the hood... hppefully there isnt no major support beams right behind the scoop...
    I remember buying a fiberglass ram air hood for my s10 for $554 about 3 years ago that was non-fuctional that we cut the scoops out but soon as we did that the hood had so much flex we had to put foam filler in to stop it from moving so much... hope i dont run into the same problem with this one..
    Jan 2007
    <div class='quotetop'>QUOTE(Jaw_Dropper &#064; Jan 13 2007, 10&#58;38 AM) [snapback]79609[/snapback]</div>
    I remember buying a fiberglass ram air hood for my s10 for &#036;554 about 3 years ago that was non-fuctional that we cut the scoops out but soon as we did that the hood had so much flex we had to put foam filler in to stop it from moving so much... hope i dont run into the same problem with this one..
    I have that hood on my Avalanche it is a goodmark hood. I had mine cut out it does have supports behind it, but I&#39;ve never seen any flex of the hood while driving.
    D
    &#39;03 Avalanche Z-71, lowered 2-3, 20&#39;s, Goodmark Hood, Waag push bar,( Radix-90mmTB, E-fans, should be here tomorrow-1/23/07 )
    Jan 2007
    does a grill come in it or do you have to make a custom grill instert?
