Page 15 of 15 FirstFirst ... 5 13 14 15
Results 141 to 144 of 144
Thread: OBS to LSx conversion
  1. #141
    Nov 2017
    HELP!!! went to stab the ls2 from my tbss only to figure out the oil pan is front sump. look at the pan on the old 5.7 looks to be a rear sump. Question is, does anybody have a part number for a pan and pickup that will fit my 99 2dr Tahoe????
  2. #142
    Aug 2014
    Quote Originally Posted by Disney View Post
    I'm swapping a 94 C1500 right now and was wondering if everyone was removing all of the stock engine harness or not. If not, did you just cut it back to the firewall connector? I'm trying to minimize the stray wires underhood if I can. I've cut the LS harness back to a stand alone, so I assume I can just tie into the stock FP relay and i'd like to tie into the stock check engine light too if I can. Keeping the stock AC plug, water temp, oil pressure, and alternator (If I need to to keep charge light off).
    Tips? Tricks? Thanks!
    Yeah, there were a few wires I kept from the old engine harness. You need a set of wiring diagrams from your 94. There's a lot of work figuring out what you want/need to keep. Then you painstakingly start cutting away the wires that won't be used. KEEP A WRITTEN RECORD OF WHAT YOU DO!!!! You won't remember in two years what you did, and at some point you'll need to know. Remember, even if there's something you don't need, you may want to use the circuit for something else. Nice wires with factory firewall connector/pass through is nice to have. For instance, I used the original fuel injection circuit to power my new harness. Just the right current rating for what I needed. Don't cut any wires till you KNOW you won't want to use them. Once I cut away all of the old, I then wrapped what was left in Nylon corrugated wire loom to keep it factory looking. (Don't use Polyethylene loom, it melts.)
    1992 K1500 Blazer.
    L94 & 6L80
    285/75R16 Duratracks
  3. #143
    Mar 2018
    I am new to this site I wanna do an LS1 conversion in my 1995 chevy k1500 4x4 and Iím lost on what to do the only thing I have is a 6.0 ls longblock any help would be appreciative thanks
  4. #144
    Jun 2018
    Quote Originally Posted by Ck951989 View Post
    Go to lt1swap.com that helped me out alot. I pretty much got everything figured out except the tranny. I dunno if I can use my 95 trans. You might have that same problem with your trans. If you can just get a newer 4l60e or 80e so you won't have to deal with it. I on the other hand want to use my trans if possible but I haven't got answer from anyone on how I can use it. I'm at a stand still until then bit good luck.
