<div class='quotetop'>QUOTE(RedHeartbeat @ Oct 25 2006, 07:39 PM) [snapback]71170[/snapback]</div>
If you are getting a tuned PCM, get your tuner to install the program for a cable driven tune. removing the DBW from the PCM requires no changes to the wiring harness that I know of. It's as simple as replacing the electronic throttle body with a cable driven unit. The truck cable is plenty long for almost any application.
<div class='quotetop'>QUOTE(kwkenuf @ Oct 25 2006, 07:51 PM) [snapback]71173[/snapback]</div>
I can verify that no harness changes are required to convert from drive by wire. Your swap is identical to mine. You can pick up a new 2002 cable operated throttle body on ebay for around $75. Used for even less.
TTT on this one...
1: Gen III Vortec TB's are different from LS1-based TB's (Camaro's, etc.), correct?
2: I noticed that the cable driven TB has 2 connectors on it, whereas my ETC throttle body has one large one, and it's on the passenger's side... Not doubting the info, I just want to ensure I'm not going to be up a creek..
Rich in N.C. - Just building your average '04 5.3L Vortec powered, 4-wheel steering, tubed, 4-linked, 42" tire shod, 2.5 ton military axle'd '73 Toyota Land Cruiser
Looking for an ignition coil for my 5.3.. Got one?
