Results 1 to 10 of 12
Thread: Parts needed for trans cooler
    Hey guys, I get asked this quite a bit so I'll just post up.
    Here are all the parts needed to install a trans cooler, as far as the cooler and connectors.
    All parts are made by Russell and are available from summit:
    670150 - -6an to 1/2"
    639200 - -6an to 3/8" tube
    624160 - 90deg -6an
    670300 - -6an straight
    You'll need two of each connector above.
    TransCooler: 70274
    This may not be your preference on setting up a trans cooler, but it'll work great.
    You can route both trans lines to this one BM cooler or just cut one line and route the new cooler inline with the stock one.
    hope this helps,
    allen
    Pics?
    Jun 2005
    Round Rock
    Okay, I have the parts... Anyone have a picture or a list of which part goes in front of the other????
    08 HHR SS
    Black on Black 5 spd with no options
    Pics of Christine, the '05 VHO My Car Domain Site
    <div class='quotetop'>QUOTE(jethro_3 &#064; Mar 15 2007, 08&#58;30 PM) [snapback]86397[/snapback]</div>
    [/b]
    check out JJ&#39;s truck, we just did it. He posted pics, or www.ls1truck.com/storage/jj
    good luck,
    allen
    Jan 2005
    Humble/Houston TX
    or you could just buy a tru-cool kit that comes with everything needed to install the cooler without cutting any of the factory lines. i got the 2800 gvw and it takes care of my 3200 converter perfectly for under 40&#036;
    old mod list: H/C/I/N/E/G 408
    new mod list: 5.3, gears/posi, mufler and tune : (
    <div class='quotetop'>QUOTE(TXsilverado &#064; Mar 16 2007, 11&#58;51 AM) [snapback]86449[/snapback]</div>
    [/b]
    Got a part number on that kit? I have the factory cooler and am thinking about adding another one for some extra protection. It doesn&#39;t get as hot here as it did in Houston (I just moved), but I would still like the extra cooling capacity for when I do go with a bigger stall
    I am interested in this kit because of the fact that you don&#39;t have to cut any factory lines.
    2007 Sierra Denali, 6.2l L92, 6L80E, 3.42s, AWD, Outlaw CAI, 160* t-stat, magnaflow muffler and HPTuners!
    Jan 2005
    Humble/Houston TX
    try "tru-cool 4590" on ebay. they have a 40,000 GVW cooler which is the largest on the market but i think its a bit overkill.
    the larger cooler is 4739
    <div class='quotetop'>QUOTE(TXsilverado &#064; Mar 19 2007, 06&#58;25 PM) [snapback]86677[/snapback]</div>
    [/b]
    Thanks for the part number...looks like the price has gone up to about &#036;70 though.
    <div class='quotetop'>QUOTE(TXsilverado &#064; Mar 16 2007, 09&#58;51 AM) [snapback]86449[/snapback]</div>
    [/b]
    I didn&#39;t see a complete kit, just a cooler from the pn&#39;s you listed above. What is the pn for the entire kit that doesn&#39;t require any lines to be cut?
    Sep 2003
    Part number with the lines and all included is 4739.I just got one and it is awesome. 40,000GVW and works great with my converter
    Did not have to cut any lines.
    Heres teh sight I got it from
    http://www.dieselsite.com/index.asp?PageAc...&ProdID=205
