i have a 03 model with 37K complete with harness computer and all accessories ready to to for 900.00
Austin Jenkins
Hi-Way Auto Parts
Brownwood Tx, 76801
800-447-0611
That would have the throtle by wire wouldnt it? Im going to have to think about this for a little while ill let you know in a day or two. If you havent figured it out im not very good at making decisions so i will let you know when i do.
5.3 computer and harness will work witha 6L Im using mine on my 6L block only diff between a 4.8/5.3 block and a 6L block is the bore size dimensions are hte same and the plugs etc. For those stuck on LQ9s get the heads milled on an LQ4 .03 and you have an LQ9 basically. The only thing better about an LQ9 is the rods but they arent that much better if you can break an lq4 rod you will most likely break an lq9 rid. ARP rod bolts are the way to go.
The 5.3 is starting to sound like the way to go until i can afford to build a better motor.
just let me know if you dont want the cabled throttle i can drop to a 02 or later and but the miles will be more and i will have to wait till i get one in so i can get it complete i have 53 of those in stock and none complete other than the 03 model
Austin Jenkins
Hi-Way Auto Parts
Brownwood Tx, 76801
800-447-0611
would that price include the pedal to make it work?
i have 2 wheel and 6 lug
04 4.8 FIPK, Pacesetter long tubes, dual exhaust with x-pipe and Dynomax race bullits, gutted cats, 160 therm, hypercrap programmer
Future mods-p/p thottle body, 02 z06 cam, within the mth. 4:11 g80 soon after......just tryin to blow my tranny
ttt
There's a stock 6.0 with tranny for $900.00 in the Houston Chronicle if anyones interested. Don't know what condition it's in.
97 GMC, 2002 LS6.
1991 GMC Syclone #1428
what can you send me the info
