Results 1 to 9 of 9
Thread: FUEL PUMPS// E85 replacements
    Jun 2020
    OK here goes.. why not replace the stock 2004 gmc5.3 pump witha E85 pump to get more flow right..afterall E 85 needs more flow for given HP!
    stock fuel pump is MU1415 or equiv as verifed by dealer.. ok fine 28GPH..tested it too .spot on.
    but I need something that will pump for 400-450 hp// so i figure get a E85 trunk pump that will fit.. NOPE
    specs says MU-1553 IS for E85 vehicles..... nope that only pump 28 gph wtf>??
    see below,,
    spent hours on delphi website seraching for E85 pump that would support 400 HP.
    NADA>.
    soemthign doesnt make sense.. so if you run E85 I guess your truck detunes itself or limits RPM??
    some pumps have same specs with higher current draws so somthing can't be right..
    so no I don't want to put in a walboro 255 that you cant find.,.. and my system is returnless.
    any freking suggestiosn to find a pump I can use>>>
    i wnated to sitkc to delphi /ac delco becasue this is daily dirver that sees lots of miles
    https://partcat.com/delphi
    Bosch 66072
    Bosch 67447
    Bosch 67535
    Bosch 69974
    Carter P76232M
    Carter P76241M
    Carter P76511M
    DENSO Auto Parts 953-3040
    DENSO Auto Parts 953-5126
    DENSO Auto Parts 953-5130
    DENSO Auto Parts 9533040
    Delphi FG0340
    ReTech RE0881S
    Spectra Premium SP3609M
    ACDelco M10101ACDelco MU1156ACDelco MU1309ACDelco MU1314ACDelco MU1415ACDelco MU1417ACDelco TS1016AutoZone DFG0340CARQUEST M3480519E3609MGeneral Motors 19133449General Motors 19133450General Motors 19167467General Motors 19167468General Motors 19303385General Motors 19303391General Motors 19331937General Motors 19331960General Motors 25349027General Motors 25376408General Motors 25384360General Motors 25384361General Motors 88965371General Motors 88965386General Motors 88965391Magneti Marelli 1AMFP00033
    Delphi Fuel Pump Module Assembly
    FG0340
    ep 0378
    fg0157 delphi
    when you look at the cross ref the specs are all over the place..
    so............... look for a camero pump>?
    remeber my system is returnless
    Thanks
    Jan 2021
    Liberia
    Pin Up Casino
    онлайн казино Пин Ап официальный сайт играть на деньги или бесплатно без регистрации
    Jan 2021
    Liberia
    Pin Up Casino
    Jan 2021
    Liberia
    Pin Up Casino
    Jan 2021
    Liberia
    Pin Up Casino
    Jan 2021
    Liberia
    Pin Up Casino
    Jan 2021
    Liberia
    Pin Up Casino
    Jan 2021
    Liberia
    Pin Up Casino
    Jan 2021
    Liberia
    Pin Up Casino
