GM LS 250k+ Miles Engine Build - Timing Chain Set-Up
Well - here is a modified set-up using Cloyes and GM Performance Parts camshaft timing components (see images). Note the REMOVAL of the small thin sheet metal strip spring from the tensioner (9-5490). The timing chain dampeners (tensioners) are used in various GM LS engine set-ups. The AFM is disabled and I'm looking to get 250k+ miles ... here we go. ... Flypast111
Reason: add more images
