Results 1 to 2 of 2
Thread: 2000 v6 to 2005 5.3ls swap
    Oct 2019
    Aiken, SC
    Hello all! Looking for advice on what direction im heading in. I have a 2000 Silverado w/ a 4.3 and a 2005 Silverado donor with the 5.3. If I understand correctly, computer on v6 can be flashed and reused on the 5.3. I will need a harness from like year v8. Motor mounts, radiator,heater, ac hoses? Fuel lines?Is there other things that need modifying? 4l60 trans. Dbc. This is a bit of a nightmare. Im new at everything and trying to learn. Ill apologize in advance.
    hot & windy
    yeah, just search around for "NBS 4.3 swap". there's a couple huge, super-detailed threads on here & performancetrucks that spell out all you need to know, even down to part numbers. welcome & good luck!
    spoiler alert - your 2000 harness won't work with an 03+ setup. alternator & PS pump can swap over (radiator, too, if you keep a clutch fan). fuel lines get cut & adapted. ac needs a couple lines & will depend on which specific compressor you get. exhaust & trans bolt right up.
    99 Sierra - 5.3 / 5spd
