Thread: Anxiety over a yoke
    Jun 2018
    Anxiety over a yoke
    95 rcsb sierra that had a v6 swapped in a 6.0/4l80 with sliding dirty dingo mounts. What 4l80 yoke do i need? I have 2 different ones and niether of them work. Both are too short. Someone out here has done this i need your help plz!!
    Jun 2018
    Anyone? Bump
    Mar 2013
    Long Beach California
    After I did my 80e swap, I had to have my drive shaft shortened about an inch or so due to the trans being a bit longer. Not sure why yours are too short. do you have the adjustable DD motor mounts? Maybe the motor needs to be slid back a bit...??
    CALI LEGAL ENGINE SWAP!
