Thread: 5.3 required tools for removal
    Apr 2019
    I've scoured the site for several hours hoping to find an answer, but i haven't found any. Does anyone happen to know exactly what tools, aside from sockets and screwdrivers, ill need to remove a 5.3 out of an early 00s silverado? Im going to a yard this weekend to pull a motor for my swap, but i want to make sure im prepared tool wise to pull it.
    Nov 2009
    SAN ANTONE
    you will need basic socket set, some pliers and some wire cutters. I would also take a long prybar also.
    Mar 2016
    BC Canada
    Fuel line disconnect tools unless you just cut the hose. Bring lots of extensions to get the belhousing bolts
    Mar 2016
    BC Canada
    Oh and bring a hack saw incase you can't get the 15mm exhaust manifold bolts off. They are a sombitch
