Results 1 to 2 of 2
Thread: 4.8 with a stock 6.0 cam
    Aug 2015
    GB Kansas
    Would like some help with this. The wife's 5.3 has cracked heads was going to just change out the heads but at 250k why. I have a 4.8 with 40k on it was going to put a stock 6.0 cam in it. Would this work and would I have to change anything else? Thanks
    Jan 2006
    Depends on the year of the engines, earlier have three bolts and later have one bolt. But why would you want change a stock 4.8L cam to a stock 6.0L cam...the specs are so close you would not be able to tell any difference in performance or sound. I can see maybe swapping in an LS6 cam, but... Is the 4.8 cam damaged?
    3-bolt cams below...
    Corvette LS1
    97-98 12554710 199/207 .472/.479 117
    98-99 12560964 199/207 .472/.479 117
    2000 12560968 198/209 .500/.500 115.5
    01-03 12561721 198/207 .467/.479 116
    Corvette LS6
    2001 12560950 204/211 .525/.525 116 385hp
    02-04 12565308 204/218 .555/.551 117.5 405hp
    Camaro/Firebird
    98 12557812 198/209 .500/.500 119.5
    99-00 12560965 198/209 .500/.500 119.5
    01-02 12561721 196/207 .467/.479 116
    Trucks and SUV with Vortec engine
    LR4 and LM7
    99 12560966 191/190 .457/.466 115.5
    00-04 12560967 191/190 .457/.466 114
    the 03-04 LM7 used the 12560967 camshaft
    LQ4
    99-00 12560967 191/190 .457/.466 114
    01-04 12561721 196/207 .467/.479 116
    01-04 LQ4 cam is same as Camaro, Corvette LS1 and LQ9 cam
    LQ9
    02-03 12561721 196/207 .467/.470 116
    GM Performance Parts
    Hot 12480033 219/228 .525/.525 112
    ASA 12480110 226/236 .525/.525 110
    01 Yukon 2wd, 547whp/576wtq @ 8 lbs - 383ci LS6, Eagle 4" crank, Crower rods, Diamond -7cc pistons, Speed Inc SC1 cam (222/228 566/571 114) AFR225 72cc heads, Crane Gold Race rockers, Siemens 60 lb inj, Magnuson MP122HH w/3.2" pulley, ASP 8-rib kit, Alkycontrol, 05 E-fans, Dynatech LTs, Corsa Touring catback, FLT Level IV 4L60, Yank TT2600, 3.42/G80 9.5" 14-bolt, Hotchkis swaybars, 275/45R20 Conti DWS06s on 20x9 Denali Repros. 12.574@110.593 1.82 60' VIDEO
