I have a 1999 S10 and a 1999 GMC both 4 wheel drive,
one has the np236 and one has the np246
both are 4L-60E transmissions,
pulled the motor from the 4.8 as one piece, and I am going to put the transfer case off the s10 on the other transmission because it has the push button 4x4.
I have the complete harness interior to exterior out of the 4.8,
can I just use the pcm out of it to make the engine run any other electrical items to look for?
any cheap headers that I can look for to replace the stock manifolds on the 4.8,
is there any oil pan I can use that will clear the cross member?
and what about engine mounts?
I was going to use the 4.8 engine mounts inside the s10 frame, but the ones on the GMC are welded into the frame, and holds the motor down with two bolts.
who sells kits, or where is the best place to buy conversion kits/mounts/adapters.
thanks for any information
