Results 1 to 4 of 4
Thread: Fuel pressure surge 5.3 swap
    Dec 2016
    South Carolina
    Question Fuel pressure surge 5.3 swap
    1992 k1500 blazer
    5.3 swap from an 03 Avalanche
    4l60e
    3k stall
    212/218 .600 cam
    Walbro 255
    I did a 5.3 swap in my blazer, from day one it has not ran correctly I canít even drive it because of has such a bad misfire. I have spent the last couple of months troubleshooting and throwing money at it but so far I have no improvement.
    It has a misfire but it isnít throwing any codes, I did drive it once and within an 8th of a mile it threw a P0101 code, i had to clear the code for it to run again.
    I have replaced the fuel pump , filter/reg, vac hoses, intake manifold gasket, MAF (with a used one) , I cleaned the Injectors and throttle body.
    I use torque pro scan app, it shows no codes, no misfires, o2s are switching.
    Here is a video of the fuel pressure https://youtu.be/S-UbH5Ogdq8
    Here is another form thread with more detailed info. https://www.ls2.com/forums/showthrea...e-tech-support
    Does anyone have any idea what the problem could be?
    When an aftermarket cam is installed the misfires are disabled.
    That's why no misfires are showing.
    Get them enabled so you can determine which cylinder is causing the issue.
    The p101 code could be a wiring issue, bad maf or tuning.
    Don't throw parts like that until this is done, it'll save money.
    Aug 2011
    New Port Beach, CA.
    Did you do the learn procedure on the crank.
    6.0 MAX Blown
