Results 1 to 2 of 2
Thread: 00 Silverado 5.3 automatic transmission problem
    My truck canít go any faster than 35 m/h it switches first and second gear but doesnít switch to third gear the speedometer works good the reverse works so I replaced the fuel filter and nothing happened then I replaced the output speed sensor and still the same now I want to replace the input speed sensor but I canít find it around the transmission does any body can tell me where is located ?
    Please .
    Aug 2011
    New Port Beach, CA.
    It maybe stuck in limp home mode. I know if there is a problem with the tps on the 2003 it will only allow you to go a max of 35 with very little power.
    6.0 MAX Blown
