Results 1 to 6 of 6
Thread: Fuel Vent Line
    Feb 2018
    Massillon, OH
    Fuel Vent Line
    89 c1500 Swap to 5.3
    What do should I do with the third line in the fuel sending unit? It use to run to the charcoal canister, I’m assuming I just vent it, just run a hose and tie it up? Need a filter on it? I’m not sure and I haven’t seen any comments in other threads.
    Sep 2011
    I have always just left the metal line open ended under the hood, could always run rubber line off and put some kind of vent on it like is on the rear end hose vent tube
    If you don't want it exposed and sometimes smell fuel vapors, run it to the air filter or near it.
    Apr 2017
    Northeast Ohio
    I was just going to cap mine. Is that bad?
    Quote Originally Posted by 1BADBOWTIE View Post
    it could be, the tank won't vent - > vapor lock
    Apr 2017
    Northeast Ohio
    My tank is the newer one with the built in vent that connects to the fill tube.
