Results 1 to 2 of 2
Thread: 97 4.3 L with 4L 60 to a 04 5.3 with 4 L 80
    Feb 2018
    Will the 4l80 hook up and will the yoke fit my drive shaft or should I get a different drive shaft or yoke? Thanks!
    hot & windy
    pretty much all GM engines & transmissions will bolt together
    a few cargo vans even came with 4.8 + 4L80 stock
    you could put a Turbo350 behind an LS9 if you wanted...
    there's plenty of threads on the 4L60 -> 80 swap, just dig around & you'll find step-by-step instructions with every part # listed.
    ain't sure off-hand about the yoke - but i don't know a whole lot on the automatics
    99 Sierra - 5.3 / 5spd
