Results 1 to 2 of 2
Thread: a few questions about 94 silverado swap
    Mar 2015
    Ive been considering 5.3 swapping my daily driver
    94 Silverado short bed reg cab 350 tbi 4l60
    Can I use the donor motors AC and PCM ?
    Can i use the stock 94 gauges ?
    Can I run the stock radiator ?
    I plan to keep my transmission for now so I know I need either a new converter or an adaptor plate.
    Also Ive been reading through threads and ive started to get a list of what I would need
    am I missing anything ?
    Engine
    harness
    motor mounts
    ac relocation bracket
    fuel line fittings
    fuel pump ( wallbro 255)
    Fuel filter
    I know I would have to figure out the exhaust past the manifolds
    Thank you in advance
    Mar 2016
    BC Canada
    Yes you can use stock rad. Your stock lower rad hose will work, but use the donor truck top hose.
    You cant use the donor ac unit in its stock location, you'll have to usr your stock one and run an aftermarket bracket.
    Your stock 94 gauges will work fine
