Results 1 to 4 of 4
Thread: Reputable supplier for 6.0 long block
    Nov 2017
    New guy here looking for a 6.0 long block.
    I recently reacquired my 2005 Z71 4.8 from my daughter and I'd like to swap out the tired 4.8 with a 6.0. I'm asking for input for a new or reman long block (with warranty) from a reputable company. I'm just looking for stock power or a slightly built motor as this is just a hunting/fishing truck that will occasionally pull a utility trailer. The truck is still in very good condition and I don't want to put a used motor in it, and I've pondered buying a used engine and rebuilding it but I really don't have the time for that. I know at some point I'll probably need to swap out the trans but I'll roll with it like it is for now and cross that bridge when I get there. Thanks in advance for your input.
    Apr 2017
    Northeast Ohio
    You should try contacting Summit or Jegs. I am sure they can point you in the right direction whether it is with them or someone else.
    Nov 2017
    I found a low mileage used engine from a 2009 Express van. I did some research and know I'll need a converter for the 58 tooth crank gear to work with my 24 tooth signal. Besides getting a tune for a 6.0 would there be any other issues I'd run into when I do the swap? Thanks
    Jan 2012
    warwick ny
    Cam sensor on the 4.8 is behind the intake manifold. On the 6.0 with the 58x the cam sensor is on the timing cover. I think the knock sensors are different also.
