What's up guys glad to be apart of the group.i need help with installing my car intake on a lq9 as far as fuel line to stock truck lines
what car intake are you using? you will need to cut your alt bracket if you are running truck accessories and may need to use a ls1 water pump if you are running a aftermarket mechanical throttle body
