you can get some dirty dingo conversion mounts, set the engine/trans into the truck and that will determine if you need to move your crossmember or if you can use it. As far as the column, there are a few options you can do. Get a auto column or you can do a floor shifter.
For tuning and stand alone harness you can PM me or email info@nelsonperformance.com
