Thread: 08 gmc Sierra Denali 6.2l fuel pump
    Aug 2017
    hey fellas, newbie here. so I've done some mods to my 08 Denali (l92) like stage 2 cam, upgraded valve train, bigger throttle body, and 1 7/8" headers and exhaust. I also put bigger fuel injectors. im having trouble finding a high flow fuel pump that comes in ready to plug and play. I can obviously buy a universal pump but don't want to do all the modifications. I was wondering if I can plug and play a l9h fuel pump which is a flex fuel pump to feed my bigger injectors? I really appreciate any feed back thanks guys!!
    Aug 2017
    nobody huh.... sweet
    Aug 2017
    Get a LS9 vette pump ,plenty for your set-up
    Aug 2017
    thanks for replying fester. so if I get a ls9 vette pump I'll be able to tune that in without getting a new ecm?
    Aug 2017
    I put a Edlebrock supercharger on my 2011 SS Camaro and while tuning it I ran out of fuel at Mike Norris suggestion I had the LS9 fuel pump installed( direct fit) and had plenty of fuel and pressure to finish the tune..
    Nov 2009
    SAN ANTONE
    i would go with a aeromotive 340 stealth, its really not hard to install. just separate the pump basket and cut the old pump out, install the new pump and plug in the provided harness
