Results 1 to 9 of 9
Thread: Help with cam for LS1 5.7 Swap in Tahoe
    May 2017
    Basically I have a 1996 Tahoe 2 door 4x4 and just found a huge crack in the L31 Vortec 350 so that engine is going bye. I just bought a 2001 Camaro SS and am pulling the LS1 5.7 to put in the tahoe. Considering this thing weighs about 4700 pounds I should get rid of the "car" camshaft. The tahoe does have 3.73 gears at least with 30.5" tires. I'm going to have 1 3/4" long tube headers, 2.5" exhaust, air intake, electric fans, STOCK STALL CONVERTER, either a TBSS intake manifold or LQ4 intake manifold, and 241 heads. I can upgrade the valve springs if needed. I do want something that is capable to tow if I need to, which would be pretty rare. It would be nice to find a cam that increases low end torque and some horsepower up top (which isn't as important) and gets around the same mileage as the stock cam. I would prefer to find a cam with .550"/.550" or less valve lift since I want something reliable, and emissions aren't as issue since I'm in Nevada, but it would be nice to not have a smelly cam. Max rpm for the engine would be 6000. Thanks for any help.
    May 2017
    No one has any ideas?
    San Marcos Texas
    Change cams if you want! The stocker will do fine for all around driving and towing. Anything you do will be better than the old L31!
    May 2017
    Quote Originally Posted by GMCwantsLS1 View Post
    Well thats good to hear, I was kinda worried about having less low end with the LS1 over the L31, since the L31 is rated like 330 ft.lbs at 2800rpm.
    San Marcos Texas
    I think the LS1 is about 350 at 2800 rpm. 375 at 4400. 385 at 4800. Revs easy to 6200.
    May 2017
    Oh I didn't realize that. I think I'm going with the Texas Speed Stage 2 Low Lift 212/218, .550"/.550" 112 LSA. It made 426hp and 411tq on a 5.3L so I'd expect 450hp and probably 420tq on the 5.7
    San Marcos Texas
    It seems better for a vehicle with more weight than a car to have more low in torque. If you have to rev the crap out of it to get it to move might not be the Best driving experience. Higher torque converter might help even with stock cam.
    May 2017
    That cam I posted made more power everywhere over the stock cam in the 5.3L on the dyno. I couldn't see the numbers under 2000rpm though.
    San Marcos Texas
    Like I said. Change the cam if you want. The stock one will work fine for a truck.
