throttle cable with swap on OBS, can't find them new anywhere
1994 silverado swap almost nearing completion,, I went to the junkyard and could not find a single throttle cable from a 96-98 vortec truck that had not been cut.. not having any luck finding a new on anywhere,,, anything else fit from another year or model that someone has been using?
I am part way through my swap as well. I used throttle cable from my donor 2001 truck. It is made to fit a round hole, where the one on my 95 was rectangular hole. I used cut off wheel to cut the sides off the snap in parts on the 01 cable and it snapped right in to the 95 rectangular hole.
thanks for the information!
I did the exact same thing been working since 2011.
