Results 1 to 2 of 2
Thread: Turbo 5.3 Piston Choice?
    May 2007
    Oak Forest, Illinois
    For a turbocharged 5.3 everyday street truck with Gen4 rods---If you had either the 4.8 or 5.3 piston sitting on the work bench---Which ones would you use? The build will probably be around 700 HP.
    Jeff
    Dec 2009
    DIrty south AZ
    I made 600/660 on 13psi with SBE 5.3
    Built 2 Run! 6XX HP/ 6XX TQ
