Results 1 to 5 of 5
Thread: 01 silverado 4.8 engine has miss
    Nov 2016
    I just bought a nice 01` shortbed with 200k seems to run ok but has a shake in engine po300 code and po308 put new plugs and wires ,switched coil same thing pulled out pass side fuel rail and swapped and still there .Havent taken valve cover off yet no smoke no noise just seems to shake like a bad cylinder but still has power so any suggestions other than a new engine would be great havent checked fuel pressure but dont think thats it HELP
    Oct 2011
    Replace the intake manifold gaskets.
    Nov 2016
    injectors 7 and 8 were plugged
    Oct 2011
    Did you clean or replace them?
    Aug 2011
    New Port Beach, CA.
    check fuel pressure regulator first with pressure gauge.
    6.0 MAX Blown
