Results 1 to 2 of 2
Thread: 01 Denali doors on a 03 work truck wiring
    Jun 2016
    Been trying to find a way to wire the doors and just can't figure it out, seen tons of threads of people saying they did it but not sure how, any help? I only care about the windows working I'm not running power mirrors
    Aug 2011
    New Port Beach, CA.
    you need to use the 03 window modules with the switches its a lan system. you can run all new wires from the driver door to the passage and use the denali o1 switches than run an ignition and ground from each door into the truck. using a 40amp relay off of the orange wire in the ignition switch to switch on and off the red/white wire at each door. hope the info helps.
    6.0 MAX Blown
