Thread: anti-theft switch...
    Aug 2009
    Summerville, SC
    Hello All,
    I have a LM7 installed in my '66 C10. I'm looking for help and ideas on the installation of an anti-theft kind of switch to make it harder to steal. Something more than just a battery disconnect switch as I want to keep power to the truck. Maybe something along the lines of an inline switch between the positive side of the battery and the starter. Or if there is someplace easier that wouldn't require heavy gauge cabling. I'm wanting to put the switch inside the cab under the dash area and out of site from potential thieves.
    Thanks,
    SKIP64
    '64 C-10 Stepside
    Aug 2005
    St. Anthony, Indiana
    Wire a switch and relay into fuel pump wiring.
    Nov 2009
    SAN ANTONE
    you can also wire in a switch to kill all ignition to pcm
