Thread: 2000 Durango gets Zl1 with 6L80 and AWD.
    Aug 2012
    Tampa, FL
    I haven't been on this site since last time I did a Dodge to LS swap. The 1999 Dakota R/T I built runs fantastic. Using a 6.0 with 6L80, I added an LS9 cam with car intake, and run about 12.5 at 107 all day long.
    Moving on.
    2000 Durango SLT with 180k miles and a worn-out 5.9. I know the motor looks clean but it was eating about a quart a week. Body is superb.
    Mock up block
    LS3
    Yeah, that's bad.
    LSA rotating assembly
    LSA crankshaft
    And supercharger to make it a ZL1
    Dodge 242 with Novak adapter
    Pulleys
    Trans and transfer case installed for measurements
    Engine is in
    Trans painted and ready
    Transfer case painted. 6 gear planetary was swapped in with 32-spline input shaft
    Trans is in
    That is as far as it is so far. I have ordered wiring, driveshafts, and gauges. And I have a bunch of little things to do.
    Nice build! Everything looks really clean, including the Durango. I have a feeling you'll surprise a few people on the street.
    2000 RCSB
    LQ9
    Torquer V2
    T56 Magnum
    305 drag radials
    3/4 lowering kit
    Aug 2012
    Tampa, FL
    Quote Originally Posted by Gemini View Post
    Thanks. I went with the Durango this time to see if the SUV body will be more rigid. Also, a little shorter wheelbase, nice leather interior, and will have front and rear A/C.
    That thing is awesome!
