Results 1 to 10 of 11
Thread: Perhaps Too Much Fuel Pressure?
    Jul 2014
    Boise, ID
    Post Perhaps Too Much Fuel Pressure?
    I still have, for the most part, a stock 5.3 from a 2008 Tahoe in my 88 K5 Blazer, so we're talking 330 to 350hp at most. I do have some JBA headers that give it a little more, but not much.
    Anyway, I have a pump I bought from Summit that dropped into the Blazer's stock sending unit fine, and I've been running it for about 7 months now. It puts out 90 psi, and I've always noticed that the truck is running rich. I think this is bad (Disclaimer: I'm not a professional mechanic!)
    Is 90 psi for my setup too much? Can/will this cause problems, and if so, what?
    Apr 2014
    What is the fuel pressure at the rail? The regulator should kick it down where it belongs unless the pump is just flat over coming the regulator.
    Jul 2014
    Boise, ID
    Pressure at the rail:
    (key turned but engine not started is 55psi)
    (Engine started is 90psi)
    San Marcos Texas
    60 is about right. 90 is too high.
    Jul 2014
    Boise, ID
    Thanks! Looks like I'll be dropping the tank again here shortly.
    Aug 2005
    St. Anthony, Indiana
    Are you using a fuel pressure regulator?
    Jan 2016
    Idaho
    Too much pressure unless you're running a lot more HP than stock. I don't know what harm it would do other than run rich and throw o2 errors.
    Jul 2014
    Boise, ID
    Quote Originally Posted by foggy View Post
    Yes. Got a corvette/wix regulator hooked in shortly after leaving the tank. The rail on my motor doesn't have one built in - some didn't in 2008.
    Jul 2014
    Boise, ID
    Quote Originally Posted by GotaluvHP View Post
    That explains the engine running rich - no codes tripping, though.
    Aug 2005
    Quote Originally Posted by 88blazerboy View Post
    I would think that you have a bad regulator than. It should regulate it to about 60 psi.
    How is your fuel system set up?
