Info Needed! T-56 swap
Hey guys ,
I currently have a 2008 5.3 - 4l60E in my 92 chevy R.C.S.S
Just looking for info as what i need if i want to swap into a T-56 trans.
flywheel? clutch? throw out bear? what about tune? cross member bracket?
Any write ups on forum -- i searched and searched..
Why?!! because i think it would be fun to drive smashing gears in a truck. lol
Thanks
I'll be doing the same swap into my 93 hopefully next week but some of the info I have found, I got a f body t56 out of a 2000 camaro, will be going with the Stg 2 diamond clutch and there fly wheel, the t56 and 4l60 are the same length so the crossmember should bolt up and as far as tunes go I'm not to sure
Oh and you need to find a clutch pedal assembly from a 88-93 I believe
- You may not post replies
- You may not edit your posts
