Results 1 to 2 of 2
Thread: N00B 89 obs swap
    Oct 2015
    N00B 89 obs swap
    Hey forum i'm Dan, and i have an 89 OBS single cab/short bed 2 wheel drive c1500 Silverado with a 5 speed, i'm looking to swap an LS into. So just here to use the search function and look over threads before the build happens!
    Question- Since i'm static dropped (5'' front/ 7'' rear) i should look into using the f-body oil pan correct?
    Dec 2004
    San Antonio, TX Area
    I would recommend it. I am lowered 4/6 and using the F-Body oil pan. It sits just above the front crossmember and trans crossmember.
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
