gauge cluster wiring
I just swapped a 2005 5.3/4l60e in to my 93 gmc c1500 and am down to a few minor things to finish it up. Gauge cluster is where i am at right now. I took the vss output from my new ls pcm and tied it in to the dark blue wire on that goes in to the 93 vss module next to the original ecm behind the glovebox. For my I have been looking at where to tie in my alternator output, coolant temp, and oil temp wires so that the stock cluster will work. I pulled the cluster and set to ohming the contacts out but noticed several of the gauges and such will tone out on the same lead so i am back to square one. Any help with this is greatly appreciated
93 GMC RCSWB Currently a 4.3 w/4L60E
