Results 1 to 10 of 10
Thread: best traction street tire
    Nov 2014
    Eagle River Wisconsin
    Okay guys, looking for a little help. I'm running 285/60/18 cooper discoverer h/t on my truck now.... I need something in that size (31.5 to 32.5 inches tall). I need to try letting a little air out yet to see what that does. I'm going to need new tires in awhile and I would like to get something that hooks up better... Looking for a street/summer tread. I need to pull my bass boat and drive in the rain so no slicks. I don't put on a lot of miles so I don't need an 80000 mile tire.. Any help would be great. Thanks, Dave.
    Dec 2009
    DIrty south AZ
    In the same boat... Need more traction but a Street/DD tire. In for some info.
    Built 2 Run! 6XX HP/ 6XX TQ
    Nov 2014
    Okay... I found these.. Not sure how much better than the coopers that I have. They look kinds cool though
    Dec 2009
    DIrty south AZ
    Ive been looking at these... don't know if there worth the $$$ for what I need tho
    http://toyotires.com/tire/pattern/pr...n-tires?cat=10
    Or these
    http://www.nittotire.com/passenger-t...ruck-suv-tire/
    Nov 2014
    I looked at those too, but they don't have them in 18s... I don't want to go any shorter because I'm running 4.56s and it would really be running high rpm if I went to a lot shorter tire.. I might just have to learn how to modulate my right foot better..
    Oct 2008
    Scott, Arkansas
    Those Kumhos suck. I had them on my truck for a while and moved to the Hankook Ventus RH07 and am on my 2nd set. Better than the Yokahamas (too hard) and last longer than the Kumhos with better traction.
    2005 Silverado SS AWD
    AEM CAI, ARH LTs, HD-2 shift kit with vette servo, Circle D 278mm 3200 stall Madtunesracing.com street tune (MTR now has a Dynojet 248 chassis dyno)
    13.82 @ 94.92 w/1.83 60'
    I have some nitto drags 305 40 18 and they work real good just my o2
    Apr 2014
    Heard good things about the Michelin LTX M/S2.
    Long Beach California
    i was in this same boat. i did a lot of research and it really depends on what your going to use the truck for. The two that i ended up debating over were the Michelin Pilot Super Sports or the Nitto nt555's. Ended up going with the SS's as they do better in the rain as i drive in the rain in winter. The nitos i believe have less tread, more of a track tire, which is not fun in water. but i believe they hook a bit better. BUT the SS's stick very well and they are harder = last longer. They made a huge difference from the crappy tires i was running before. ill still light up the tire from a launch but it hooks up in half the time it used to. once i get the tru trac in, it should eliminate most of that. im super happy with them. just my .02
    Jul 2019
    Panama
    Hey Tom Sounds like me and my tire blow-outs - only 5 years old when my pants went dark What brand were those tires?
    honestly thinking of switching to Continentals.Anyone using their newHSR2 eco plus tires
    Thanks to all
    Marino
