Results 1 to 5 of 5
Thread: 51 chevrolet truck.
    Dec 2013
    51 chevrolet truck.
    found a 51 chevrolet truck. Running and driving all orginal. Solid truck. My buddy's farther truck. Going Saturday to possibly pick up.
    I found a chassis donor vehicle 97 s10 2wd standard cab long bed. From what I read this is the kind of s10 easier frame swap. Wanted some thoughts or opinions.
    The s10 is 2k. I'm hoping that I can put body on s10 frame than fit 5.3 or 6.0 in place of the 4.3.
    Any thoughts or opinions or advice on the comming project.
    Yeah I would read and read like crazy. Measure twice cut once. Here is some good info that I like to look over:
    http://www.killbillet.com/showthread...-52-Chevy-S-10
    I would love to see that project.
    May 2007
    Oak Forest, Illinois
    Here is the site you need to check out. There are MANY S10 frame swaps here and lots of good info.
    http://67-72chevytrucks.com/vboard/f...splay.php?f=13
    Jeff
    the 51's still had that split front window, right?
    Man, I don't know what I'd do if I found a solid '51 - but it would be ssssttttttttuuuupid by the time I got done with it. Just straight rat rod style, loud and dumped on it's nuts.
    If you don't buy it, you have no balls. Nooooooo baaaaaallllllllsssss.
    *doitibetyouwon'tdoit*
    *poke*
    *poke*
    *doubledogdareya*
    I like things with spark plugs...
    ... oh, and boobs - I like those too.
