So on the way home last night, I felt the truck shudder and about 20 seconds later heard and felt the drive shift brake loose from the rear end. After I had the truck towed home I, took a look under the truck to see the damage. It appears that the transfer case locked up and turned the drive shaft into a pretzel as well as putting a grand canyon wide crack in the transfer case to transmission adapter. Has anyone ever seen anything like this? The rear-end rolls freely. There was no whining noise prior the event from the rear-end. I plan to take it apart this week for further inspection.
