Looking to pick up a little cam for my 4.8 reg cab and don't want to run too much spring. Specs are 208/212 dur and .554/.558 lift with 115 lsa. Trying to give the daily a little boost in power with a set of cleaned up truck heads with 2.00 intake valves and a NNBS truck intake. Reason for this cam choose is so I don't have to run a higher stall converter or gear change. Trying to go for fuel mileage and I will be installing a 05+ rad/elec fans and UD pulley.
