Originally Posted by
dougbert
Well, with my own research (Doh!) I found:
20 gallon Fuel tank Dorman 576-336 $93
Airtex E3947M, $118
My 1984 has dual tanks. Pondering on how to utilize the second tank, maybe as an auxiliary and use a transfer pump to move the fuel to the primary.
As I understand the fuel level is a 40-240 ohm, while the 1984 is a 0-90 ohm. Still researching that
thanks for the thread, it gives me options
Hey! sorry just getting back to you, been busy.
I had dual saddle tanks 16 gal each. went with a single 20gal on drivers side.
for the fuel level i havent figured that out yet. i went with a gauge cluster from a 1991 suburban (all electronic) so once i figure out the pinouts and wiring etc with that, then i can wire the gauges in.
1983 C10 RCLB 5.3L/4L60E Swapped 2wd.
2000 GMC Sierra 5.3L/4l60E 2wd on 24" Devino Concepts
