My '93 4x4 went pretty well. Manual shift transfer case bolted right up to a '99 4L60E out of an Escalade. I spliced in the VSS to the harness because the plugs were different. I did have to modify the shifter linkage since my '93 is not cable shifted but shifted with linkage from the steering column. I had to cut and reweld the original bracket to work with the shift switch on the side of the trans.
John
