Thanks, I read the 96+ fuel pumps run at higher pressures. So would you advise doing the harness splice/repin or just get the plug and play nelson harness?
Like I said I am just getting a long block pretty much, unclear if I even get the intake manifold or exhaust manifolds. Only reason for being pulled is a retired couple uses it to pull their RV and the trans was getting hot so they just replaced the engine while it was easy (only has 60K on the truck). It will get headers and a TBSS mani if it comes down to it.
I wont be going for high performance right away. Mostly just a reliable work truck until I get some maint done on the 2 Dmax's, then it might get a super charger.
06 K2500HD CCSB DRW Conversion LBZ 6 Speed Allison Idaho Rob EFI Live 255K
03 K1500HD CCSB Quadrasteer LQ4 4l80 Blackbear Performance EFI Live 195K
02 K2500HD SCLB Feed truck LB7 5 Speed Allison Bad Injectors 190K
95 K1500 ECSB 6.5L 4l80 295K 6 setting PCM WH1C hybrid HX40 turbo
94 K3500 SCLB 6.5L NV4500 350K 6 setting PCM ATT (original long block never opened up)
93 K3500 C&C 6.5L NV4500 235K Bull Moose Injection Pump A Team Turbo w/ QSV
