P0300: Intermittent Misfire
The back story. I recently swapped a 2001 5.3 LM7 into my 1998 K1500. I rebuilt the engine but reused a lot of the peripheral components. Since initial fire up I have been experiencing a menacing P0300 code. I have an Autocal and have been able to monitor individual misfires on all cylinders. The primary cylinder that consistently misfires is number 4.
The conundrum. At initial start up the engine runs fine. However, once I get about a half mile down the road the misfire begins. The misfire seems to happen primarily between 1300 and 2500 RPM. If I put my foot in it, the misfire goes away and the truck revs to redline really well. Then back down to cruising RPM and it begins to misfire again. The engine revs fine in neutral and park. If I shut the engine off and immediately restart the misfire goes away, but comes back shortly after.
Corrective actions I’ve taken with no positive results. I have changed the plugs twice. It currently has AC Delco Iridium plugs. I have changed the plug wires. I have swapped the coils on cylinder four and the fuel injector on cylinder four. I have checked for vacuum leaks and found none. I checked the fuel pressure regulator and it is not leaking into the vacuum tube. My tuner said fuel pressure looks good. The fuel filter is new (AC delco part). I tried running the truck with the MAF unplugged and it helped for a little bit but then the truck started running even worse than before. The catalytic convertors are relatively new Magnflow parts that functioned just fine with my 5.7 L31.
The truck does not have EGR and when I had the engine apart the intake was thoroughly cleaned as well as the injectors. Truck also has a brand new Camshaft position sensor. I am assuming that if the PCM was bad my tune would tell me. I’ve exhausted everything I can think of to remedy this misfire and I’ve searched for hours on the internet trying to find a solution so I’m here asking for advice.
Things I haven’t checked: Crank positions sensor, O2 sensors. Again, I am assuming if either of these were causing a problem the tuner would let me know.
I cannot understand why the engine does not misfire at all RPM, not all the time and not when revved in neutral and park. Truck also seems to idle fine. I would think if it was a problem with the harness it would be more consistent and would not subside just by turning the truck off and then back on.
Mine was caused by carbon in the heads, do a compression check
Today I replaced the MAF with a brand new Delphi part. I also replaced the fuel pressure regulator with a new unit. I'm now getting P0101 and P0175. Truck is also backfiring through the exhaust under light acceleration. Seems like I'm going in the wrong direction. Misfire is worse rather than better. Also, I've noticed when I hit 3000RPM the truck has a surge of power up to nearly 6000, the feeling is almost like that of turbo lag, then a surge when boost comes on. Of course this truck is not turbocharged so I'm unsure what is causing it.
Update: Problem still not resolved. Time, money and parts thrown at this thing with no success.
New plugs, wires, MAF sensor, MAP sensor, O2 sensors, fuel filter, fuel pressure regulator, new grounds for the coil packs, swapped coil packs around, swapped fuel injectors around, New tune, crank relearn, additional grounds run to the ECM and additional ground strap run from the block to the chassis.
Still having the same problem. Low RPM misfire from idle to 3000RPM. When the truck hits 3000RPM the misfire stops and it takes off like a rocket. It's like flipping a switch at 3000rpm. What would explain this?
Had that problem before on a Yukon it was an injector pigtail
And on another (corvette c5 bone stock)same code it was a broken valve spring
Good luck
- You may not post replies
- You may not edit your posts
