Results 1 to 9 of 9
Thread: breather kit
    breather kit
    I have Tricks turbo kit on my truck but it doesn't really leave room for a breather coming out of the oil cap. What are you guys doing? I don't need anything fancy just something to get the job done. Thanks
    Remove rocker cover.
    Drill a hole.
    Install fitting.
    Put little filter on the fitting.
    That's simple.
    Jun 2013
    Jersey Shore
    No PCV needed anymore?
    1995 GMC Suburban 7.4L S/C (339whp/530wtq 5lbs) Whipple off, 454 pulled - 6.0 twin turbo swap started
    2010 GMC Sierra Denali AWD
    SOLD: 2004 Dodge SRT-4 S3r (11.6 @ 117)
    www.tabtransmissions.com
    i posted for a simple one.
    Remove pcv hose and cap intake.
    Put filters on both rocker covers.
    The more venting, the better.
    With your setup, i'd do it bigger. put som -10 or -12 fittings on the covers, run both hoses to a catch can with a filter.
    Jun 2013
    Jersey Shore
    Ok, thanks man. I havent got much time in on the motor assembly lately. It has crank and 3 pistons in lol. I did however paint clear and build the nv149 with the machine input shaft. If I can only have an extra 2 hours a day I would be set!
    Not enuff hours for mods!!!
    Thanks pretty simple and to the point, thanks! I'll to look into the -12 fittings and a catch can. Farmtruc I sent you a pm.
    Never is enough time for mods but I still manage to make time...!
    Dec 2011
    Savannah, ga
    i did the boosted catch can from Mighty Mouse on ls1tech
    1997 RCSB, AES 390 + 4L80E transplant, F1A Procharger, #160 injectors, Magnafuel 750, Schoenfield Longtubes, 3" flowmasters, Steve Morris Bullit cam, Circle D 3k stall, Ford 9" rear, Homemade Caltrac bars.
