Your main hoop looks low
Are you a shortperson by any chance
Main hoop is fine I couldn't really go up any higher with it.
Reason I asked is main hoop is supposed to be higher then drivers helmet. I'm 6' and I had to tuck my main hoop higher.. the bottom of my main hoop is barely seen from cab. Its probably little over 2" higher then yours and mine is tucked up against the back of cab. I did away with the coat hooks
On I get wat hour saying now. I didn't research that enough I guess. I'm also 6' so it may be too short. Unless I get some seats that sit way low lol
Look for pics in my garage and you'll see what I'm saying
