I grabbed a low mileage 6.0 LQ4 out of an 05 Yukon XL Denali w/ 56k.
I so far pulled heads off, stripped it down to just about the block and rotating assembly to inspect things and of course do new head gaskets.
I am going with twin PTE6266s and going to run low boost. I want the truck to feel like a factory boosted truck with stock like mannerisms. Its being dropped in a 95 GMC Suburban K2500. Hence the reason why I went with the parts I got so far.
Purchased so far:
New LS9 Cam
LS9 Head Gaskets
LS2 Front timing chain cover kit
LS9 Valve Springs
High Volume Oil Pump
Upgraded Timing Chain
Now I also ordered a LS2 Chain Damper but then realized when I got the engine apart it does not have the bolt holes in the block for it. So what do you guys do in that situation?
Also did I miss anything so far? Looks like I got lucky with the 05 having a 1x cam gear so that saves a few dollars.
According to Lingenfelter the stock pushrods should be sufficient but I am going to measure them to double check.
The engine is not as clean as I wanted so I will most likely pull the rotating assembly out and really get this block cleaned up and prepped.
