Results 1 to 10 of 10
Thread: Looking for a good cam
    Jan 2014
    SAN ANTONIO
    first got a 2013 single cab Silverado 5.3, cat back and CAI with a custom tune best time 14.4, been looking for a cam...basically something I that will give me good power and driveable with some chop. more of a street/strip cam so far got a standard valley plate and non-dod lifters, going to get rid of the AFM so any help thanks
    Something like a 222 duration.
    3600 stall converter.
    Jan 2014
    SAN ANTONIO
    Cool thanks
    Feb 2012
    man that's good time for the modds, I would get headers before the cam, because your motor won't be able to push out that extra air as well on the stock manifolds
    Mar 2011
    Mississippi
    What gears are you running? I agree with canada4g63, I'd get some long tube headers as my next mod.
    * 2004 Chevrolet CCSB Z-71 5.3L * G80, 3.73's * Black Bear Autocal 91 oct tune * Magnaflow 3" SI/SO 14" case * Airaid M.I.T. * OEM airbox with open air modification * Color matched grille & lower valence * Blackened Tail Lights * SuperBright LEDs in brake lights & reverse lights *
    In the garage to be installed: 799 heads, Dyna-Tech long tube headers, Corvette servo, 2" lowering shackles, 2wd u-bolts & bumpstops
    It's usually awesome to have LTs with any cam however I have seen plenty of guys pick up over 50rwhp from a cam with stock manifolds.
    there are quite a few guys running 220/220 cams in the older 5.3s making good power and they sound awesome but that maybe a little wilder than what you want, i know the stock ls6 cam pushrods and valve springs will fit a 5.3 and are making good power and the price on them isnt that bad either
    there is a wild 220r cam? there days small cams are killing that cam and huge cams are making better power than ever... that cam honestly is so like 6 yrs ago. custom grind all the way... itll be built for your truck and how you want it to perform!
    Jan 2014
    SAN ANTONIO
    Long time since ive been here, want to say thanks to Nelson Performance for the bad ass E85 tune in my truck and DriveShaft specialist for there monster driveshaft cant wait for the next truck shoot out here in San Antonio or the RGV. highly rec these guys
    Feb 2010
    Central Texas
    I put a comp 222/224 in my buddy's 65 p/u with a 5.3/4L60E/3.73, works really good
