Originally Posted by
farmtruc
no problem at all.
once you have removed all the misc wiring and sensors that aren't needed; in short, YES.
I like to separate and group certain sensors together, but if you were to take all those pink/ignition wires and take them to a single 12g wire, it would work.
Just use the correct fuse.
Suggestion:
Take the pcm ign to it's own source.
Group maf and o2's together
injectors on their own wire
coils on their own wire
just a general suggestion, by no means is this the correct or wrong way, it just might help if you need to diagnose why the engine isn't starting.
