ok so ive searched and looked through all the threads on here and google and am having some trouble...
so ive been having the lean codes on both banks and i finally got them cleared up today. ive only drove around for 15 min so im not sure if its completley fixed or not but the pcm is saying im ready for emissions testing.
i sprayed carb cleaner all over and the only leaks i found were on two injectors. so i replaced the orings and that fixed those leaks but not the codes. i then decided to change the intake gaskets as i couldnt obviously get carb cleaner under the intake. THAT is what seemed to clear the codes.
NOW heres my confusion. everywhere i see is that the STFT and LTFT are supposed to be damn near 0% with some obvious fluctutation. my STFT's are right there. but my LTFT's were pegged at 25% before the orings/intake gasket change. now the LTFT's are fluctuating between 15-24% with an average of about 17% i guess the computer thinks this is ok enough to not throw the codes but im not satisfied with it.
all my hoses look fine and i cant find any leaks. my fuel pressure at the rail is about 55psi while running so im pretty sure the fuel filter/pump, which are new, are just fine. the pressure regulator is also new. the injectors are 50#ers of a 12' 6.0 with less than 1k on them so i think they are good to go.
map and maf sensor readings are where they are supposed to be and i cleaned the maf about a month ago.
all intake piping clamps are tight. i understand if both codes are present this means it should be air entering after the maf but before it gets split between banks OR i have leaks on both banks. but the new gaskets should have fixed the latter....
i also understand that the LTFT takes a little while to settle into range. so should i not worry about it for a while and just keep an eye? or a i missing something?
i dont have a smoke machine and id prefer not to pay a shop 100 bucks to smoke it. only other thing i can think of is TB gasket but the carb cleaner showed no signs of leakage there....
what gets me is that it idles kinda rough. id say its about 70% smooth. is this normal? are my readings ok? or is there possibly something else thats causing the roughness that has nothing to do with a vacuum leak?
sorry for the lengthy post. just trying to give as much detail to help in the diagnostics. im ready to take it to the ref for testing and dont want any issues. any help would be awesome. thanks!!
