Results 1 to 7 of 7
Thread: Spark plugs
    Jun 2012
    Carrizo Springs Tx.
    Spark plugs
    I had some oem spark plugs, they were fine then I bought some ngk tr55 part number 3951.. And gapped them to 40 and when stomp on it from a dead stop it's super sluggish. Then it's pulls after.
    But with oem plugs it would bark 35s just alittle.
    With tr55 at 40 gap it would not.
    Should I gap higher
    Mods: CAI,Magnaflow Exhaust, Calspeed LTs & ORY, Airaid TBS, Vette Servo, Nelson Performance Tune
    Future Mods: 4.56 gears , 212/218 cam, stall converter and 100-150 shot, Rebuilt tranny.
    why are you gapping them ?
    01 GMC REG CAB BUILDING
    Quote Originally Posted by A PATRIOT View Post
    "MOLON LABE"
    Factory gap is .060. Only need to close that up for n2o or boost.
    Mar 2010
    San Antonio, Tx
    TR55 are pre gapped should be .060, leave it there!. The OEM Iridium plugs have .040 gap. Any non-iridium plug needs to be .060 unless different cylinder pressure
    than stock.
    2002 ECSB 2WD 5.3
    1995 Formula Firebird 383 LT1
    1984 Camaro 408 SBC
    Most sports require one ball, motocross requires two.
    Racing isn't a matter of life and death, it's much more important than that.
    Apr 2012
    LaVista Ne.
    What gap if different than stock cylinder pressure?
    X2 on not adjusting the gap.
    Nov 2009
    SAN ANTONE
    i would set the gap to .045-.050 with a tr55 plug
