Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: Best Cam for 4.8 L for significant hp gain?
  1. #11
    Yes you need new springs and hardened pushrods. The HU1 from sd parts is a great option 212/216 low lift I believe or anything under 220 duration should be fine. A 212/218 is great or the isky triple 12. Good mild cams. A proper tune cam and exhaust will get you around 325 to the flywheel.
  2. #12
    Sep 2010
    North East Ohio
    Pushrods, springs are required, Keep in mind that sounding fast and being fast are 2 different things unless your are willing to go all the way with other supporting mods (stall, Gears) You are fighting an uphill battle with 4.8 and torque. Ask me how I know.
    2010 Silverado 4.8 Ext Cab 4x4
    Cam, Stall, 4.88's
  3. #13
    Quote Originally Posted by Gus View Post
    You need to keep in mind this is most likely going in a much lighter weight 1960 2wd rcsb. He can likely handle a lot more can than your truck which weighs 1000+lbs more than this truck. This is also more of a toy. Your truck is a DD with truck activities like hauling and offroading. Being a street truck with out a stall I would again suggest the HU1 from scoggin dickies. Safe to run yellow springs which saves money and will run strong while sounding good too.
  4. #14
    Aug 2013
    Thumbs up
    Thanks for all the suggestions and yes this is going to be a toy. I'm going to run 3.73 gears, and I'm still researching a cam...... Sounds like the 212/218 comp camp .522 .529 with 114 LSA. Going to spend a bit more now, going with a 3400 and once the truck is running (April) I'm going to research turbos and or supercharger. Would this cam be a good match for 3.73s, 3400 stall and a supercharger ? Or should I go more aggressive? I thought I read something somewhere that said to keep the LSA down if you were going with a supercharger but I might be wrong. Truck overall maybe weights 3000 lbs.
    Thanks again for all the help guys !!!!
  5. #15
    Dec 2008
    South Carolina
    Iv got a comp xr275hr cam for sale. 222/224 .566/.568 112 lsa. It would run good with a 3400 stall. Pm me if your interested
  6. #16
    Quote Originally Posted by chvy=power View Post
    Is the 112lsa an issue with boost or is it more about overlap?
  7. #17
    Jan 2014
    what about a lq9 6.0 stock going with long tubes first. looking for best order to upgrade?
